-   -   454 Cu In LS7 short block (Darton M.I.D., Callies, Titanium rods, Katech Pistons) (https://www.lateral-g.net/forums/showthread.php?t=22700)
Bowtiguy 09-17-2009 09:36 AM
SOLD./..
I originally had the rotating assembly listed for sale but now the entire package is available. Cost me close to $12K to put together, but I no longer have a car for it to go into.
I've decided to sell this short block assembly "unassembled". I know if I were purchasing these items I would like to do the final machining assembly or have the engine builder of my choice do the work.
Included in this package...
LS7 BLOCK
-the block started as a new LS7 block in march 2008
-It was recently ( last week) resleaved with Darton M.I.D. liners by Steve @ Race Engine Development ( will require finish bore, hone, rod clearance)
-Machine work completed on the block
1) stress relieved
2) machine /install/ "0" deck block
3) includes ARP main studs ( used for align hone)
4) cam bearings installed
5) GM billet main caps
-More info on the Darton M.I.D. system can be found here...
http://www.dartonsleeves.com/midinfo.html
-Darton M.I.D. tech manual
http://www.dartonsleeves.com/mainpage.htm
Rotating Assembly
This assembly is completely balanced and marked for easy install.
It includes the following components..
A) Custom 4.185 katech FORGED pistons
-.927 DLC coated pins
- coated skirts
- ceramic coated tops
-factory deck height install
-uses standard JE Ring pack Part# JE J70008-4185-5
-pistons specs are as follows
11.5cc Dish
1.105 Compression Height (this is “0” deck @ 9.235 Block Height)
4.185 Bore (install these with 0.0043-.0055 P/W clearance)
Designed for 11:1 Compression w/ 69cc combustion chamber/4.125 stroke
NOTE: The PIP mark on the crown of the piston needs to face the REAR of the engine upon installation.
(If standing in front of the engine, ALL pin offsets will be to the left.)
B) GM Titanium Rods
- use standard .927 chevrolet pin
- Rods include ARP fasteners
- Katech rebushed small end with high modulous bushings ( $700 upgrade)
C) Custom Callies Magnum crank shaft ( waited 3 months for this one)
- 4.125" stroke
- clearanced for factory GM titanium Rods
- 58 tooth reluctor wheel installed/welded into place
- gun drilled
- chamfered oil holes
- pilot bearing installed
- completly balanced for the Katech piston/Ti rod assembly ( 1042 grams each)
- long snout for LS7 applications ( can be cut off for wetsump/LSX builds)
- keyed for driving LS7 oil pump OR LS1 style pumps
-drilled for ATi pin to avoid balancer slipage
-standard 350 chevrolet clevite 77 H series bearings both mains and rod.
Crank is 11 lbs lighter than stock. 4.185 pistons weigh less than the stockers ( this thing spins WAYY faster than a stock LS7 motor). Each piston/Rod assembly weighs just 1042 grams!!!!
Actual Cost to Duplicate this package
LS7 block ( new) $2800
Darton M.I.D. liners $1500
Labor to install liners $ 750
ARP main studs $ 185
Align hone( w/ ARP studs) $ 300
Callies custom LS7 4.125" stroke $2000
Katech Custom 4.185 pistons $1272
Katech piston design fee $ 127
Katech skirt coating of pistons $ 165
Katech DLC coated pins $ 280
GM Titanium LS7 rods (street price) $1500
Katech rebush small end $ 710
ARP fasteners $ 150
Piston pin fit/assembly $ 76
Total ------------------------------> $11,815
Rather than set my price high and haggle down, I've come up with a price I feel is fare. Anything less and I'll keep it for a future project.
[ E-mail me for payment details.
local pick-up available North Denver 80516.
Bowtiguy 09-17-2009 09:39 AM
Katech Piston, Titanium Rod, ARP assemblies
1042 grams!!!
tones2SS 09-17-2009 10:51 AM
WOW!! Hell of a price for a what will be a killer engine. Nice parts list.
GOOD LUCK!!:thumbsup:
Bowtiguy 09-17-2009 12:47 PM
Thanks,
I figure it will move fast at this price. decided to head up to the high country this weekend and chase some dusky grouse with my bird dog, so anyone with serious interest can call me at (303) 489-7346. No computer access until sunday PM.
-=MIke
buickfunnycar.com 09-17-2009 04:17 PM
No doubt,good on you for pricing this where you did,should sell quickly...good luck!:thumbsup:
Bowtiguy 09-20-2009 08:31 PM
Thanks! All PM's replied to...
or you can e-mail me directly...
[email protected] :thumbsup:
GMracer 09-21-2009 06:59 AM
:_paranoid
Man I want it, good luck with the sale!
tones2SS 09-21-2009 08:33 AM
Originally Posted by GMracer (Post 235808)
:_paranoid
I hear ya Nick. I want that engine as well. No job = no play!! lol:mad:
Bowtiguy 10-02-2009 07:50 AM
everything is still available. I'll be out of town for the next couple of days
Bowtiguy 10-12-2009 07:40 AM
will be in town for the next two weeks.
I'll include the custom LS7 camshaft ground for me by LSM. thios 242/249 .650/.650 114 LSA cam helped this short block make 572/538 rear wheel #'s with milled LS7 heads. Add some real heads to this package and the magic 600 RWHP will be no problem...... along with daily drivability.
Complete package is still available.:cheers:
