The New Ultimate Sample Kit
This new Introductory Kit is the perfect size to sample our products, for the small touch ups at shows, or for the motorcycle enthusiast. This kit includes six 4oz. bottles of our most popular products.
These 4oz. Bottles are perfect size to store in your car or the saddle bag of your bike. You never know when you are going to need that little touch up to make your vehicle or bike look the best it can! Nobody has the room to store large bottles in their cars or bikes to make sure they have the perfect shine, but now you don’t have to worry these 4oz bottles are perfect for traveling. Also if this is your first time looking at our products and not too sure what to get, this is the perfect kit to get professional car care products in a easy to use sample size. $32.95 Detail Spray: Billed as the slickest lubricant and detailer available. The wet look comes from a polymer resin base with wetting agents and lubricants. The anti static formula will reduce static charge and will help get rid of those annoying fingerprints and smudges. Metal Polish: Pedal To The Metal™ Polish & Sealant cuts through layers of dulling oxides restoring reviving and enhancing a wet-mirror like finish that shines better then chrome. This outstanding polish makes chrome, copper, brass, aluminum, stainless steel and other metal work gleam and look their ultimate best. Wax Detailer: delivers a superior wet shine sprayable paint sealant coating. Speed Glaze can also be used as a wax or sealant booster to enhance shine and durability. Scratch & Swirl Remover: Wet Wax leaves your car shining like it was just washed! Wet Wax contains no cleaners or abrasives, and will not stain plastic or rubber. Scratch & Swirl Remover eliminates scratches, swirl marks, oxidation, and spider-webbing, overspray and most surface imperfections in one easy step. Wet Wax: Our wettest wax ever and delivers an unmatched surface shine and wet look. Wet Wax leaves your car shining like it was just washed! Wet Wax contains no cleaners or abrasives, and will not stain plastic or rubber. Vinyl, Rubber, and Tire Dressing: A multi-surface shield for your vehicle's interior.Dual action premium dressing leaves surfaces 100% dry to the touch and shining better then new, while protecting the surface against dirt and dust. Your vinyl, rubber, and tires will shine for months shielding and protecting against the elements. Maintains a 100% dry never greasy or oily supple, fresh texture of vinyl, leather, plastic, rubber and tires http://i602.photobucket.com/albums/t...ini0022323.jpg *** ALSO AVAILABLE IN INDIVUDUAL BOTTLES - PRICING RANGING FROM $3.95 TO $5.95 *** VISIT US ONLINE |
| All times are GMT -7. The time now is 12:15 AM. |
