1st gen chassisworks subframe/Fresh 12 bolt/Wilwood/Hotchkis Package - Also 700r4
Full suspension upgrade for 1st gen camaro's minus rear shocks:
Complete Chassisworks subframe powedercoated black with rack, coilovers, wilwood brakes. 700R4 crossmember. New 12 bolt powdercoated black with new GM 3.73 posi, moser axles, all fresh. Hotchkis 1.5" drop multi leafs - new Wilwood dynalite rear brakes - new Also available is a New Mad Dog Transmissions 700R4 with high temp raybestos 9 clutch pack (replaces factory 5 clutches),all new steels, bands bushings and rings. A 500 boost valve, 4140 hardened pump rings, a 29 element sprag, Over sized heat treated Sonnax sun shell, hardened input shaft N drum, high temp pro series raybestos kevlar band and a corvette servo. with converter, tv cable. Will only sell with subframe. All for $6900.00, $7600 with 700R4 prefer not to ship - in Austin, TX Can sell 12 bolt separately for $2100. Can take pics if needed. John (512) 748-5677 |
| All times are GMT -7. The time now is 12:11 AM. |
