115v 20 amp welder question?
Does a 115v 20amp welder need a special plug in a house or will a standard garage plug work? Is this sufficent enough to do sheet metal work on a car?
yes its a reg 3 prong 115v plug. you want to make sure its a 20 amp circuit, both the breaker and it being #12 wire to the outlet, its best to use an outlet with nothing else running off it.
yes it will weld anything you need ot weld on a camaro |
I am a huge fan of this welder
http://www.hobartwelders.com/product...ed/handler140/ I got mine on Ebay new for 400.. you can also get them at tractor supply. I have 110 three prong 20 amp circuit (mine are still the old glass fuses) Never had a problem with blowing the circuit. It easliy welds sheet metal and steel tube. (made a body cart not problem) |
Awesome thanx guys!
welder will be fine for what you need it for.but the power will drop off like a rock if you plug an extension cord into it so make shure the 20 amp outlet is close to where you need it.if you need an extension cord use a short as possible and a big cord.:thumbsup:
Where are you at with your project? It's been a while since we last talked. |
Lots of us use abrasive wheel 'chop' saws - but that wouldn't work for you unless you can setup outside and off the driveway. They throw off tons of sparks, smoke like hell, really noisy and stink up a garage quick. I've also had friends use them in the driveway - and when the grindings get wet - they rust and stain the mad owners purdy driveway....
http://www.harborfreight.com/cpi/cta...emnumber=44829 I use a cheap Harbor Freight band saw for the basic cutting jobs: http://www.harborfreight.com/cpi/cta...emnumber=93762 A bit slow - but if you use quality blades the final results are good IMO. Jim |
| All times are GMT -7. The time now is 11:00 PM. |
