New 5.7 Hemi Stroker 370 CI
New 5.7 Hemi based 370 cubic inch stroker short block, 0 miles – Custom ground crank, Carrillo rods, ARP rod bolts, custom CP pistons (8.5:1 CR with 5.7 heads or 10:1 CR with 6.1 heads), Tool Steel Pins, balanced and assembled, Degreed Comp XFI260 cam, new timing chain set. Full gasket set included. No Core, asking $4000.
http://img.photobucket.com/albums/v1...e/DSCN1513.jpg http://img.photobucket.com/albums/v1...e/DSCN1514.jpg http://img.photobucket.com/albums/v1...e/DSCN1515.jpg Thank you -Chris 951-551-6181 [email protected] |
I will split shipping with anyone in the lower 48.
Thanks -Chris |
BTT
Maybe some perspective helps. New you can get this for $5000 + core charge ($400). I have no core charge. My engine has Carrillo H beam rods, which are stronger then I beam and certainly an upgrade. I am also including a full gasket set (head, oil pan, rear main, timing cover, valve cover, etc). On top of that I am splitting shipping, which usually is a deal killer. Thank you -Chris |
New price is $3750 Shipped and I'm including a new 6.1 balancer.
| All times are GMT -7. The time now is 12:05 AM. |
