-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   Light 12v Optima? (https://www.lateral-g.net/forums/showthread.php?t=25670)
Sti_Guy 03-09-2010 12:43 PM
Light 12v Optima?
OK so what im looking for is a light weight optima battery. I want the quality of the optima battery but in a smaller package. Maybe one that is half the size/weight of the current unit i have. Or has this just been something others have brought up and just never goes past that point?
SLO_Z28 03-11-2010 01:15 AM
The yellow top group 51 is strong enough to crank over most applications. Id look into that.
tukes23 03-11-2010 07:07 AM
Oddessey
All of the optimas are pretty much the same size and weight. If you're looking for something lighter and small but still with the same quality, I would look into Oddessey batteries. They seem to be a bit more expensive than Optimas but the quality is better and you paying to lose quite a bit of size and weight.
Garage Dog 65 03-11-2010 09:26 AM
Might try 2 six volt Optima batteries. Not sure if there is a weight difference - might actually weigh a bit more. We used 2 in series in a 33 hot rod. Mounted them in the left side panel of the trunk. LS7 engine - No problems cranking it over at any time.
Jim
nvr2fst 03-11-2010 05:10 PM
If its in the budget
Braile
David Pozzi 03-11-2010 07:56 PM
Optima 8071-167 is a group 57 T2 yellow top, it's 450cca 27.2 lbs, and I was told it is used in race cars for lighter weight. There might be a red top version with more CCA's.
Any AGM battery is already lighter than a flooded type battery.
GregWeld 03-12-2010 06:12 PM
If you want light weight -- these are even made in carbon fiber!
http://www.braillebattery.com/index....tteries/b3121/
Sti_Guy 03-12-2010 08:37 PM
I've done some research on all the other brands out there, but I really have my reasons for wanting to stay with an Optima. The market could use another contender. Ill just stick with what i have the battery hold down is already welded in the car anyways. :)
