-   Cars Sold (https://www.lateral-g.net/forums/forumdisplay.php?f=77)
-   -   73 z28 (https://www.lateral-g.net/forums/showthread.php?t=26187)
camaro73 04-03-2010 06:15 PM
73 z28
3 Attachment(s)
400 4 bolt main
.40 over
350 steel crank
GM polished rods
10.1 Compression
280 comp cam
AFR aluminum heads 195
Hooker Jet Hot coated headers
Flow master exhaust
Roller rockers
650 Demon carb
Edelbrock RPM airgap manifold
TCI starter
Billet steel flywheel
Be-cool aluminum radiator
Dual 13’ fans
6 Speed Richmond transmission
Long shifter
Dennys Aluminum 3.5” drive shaft
12 bolt 3.31 gears
Superior axle
4 wheel disc brakes
Drilled / Slotted performance rotors.
Wilwood up front GM in back
Stainless steel brake line.
B body spindles
Close ratio steering box
Centerline starlite wheels
275/40/18 0n rear
255/45/17 up front
Falken Performance tires
Hotchkis 2” drop in front with sway bar.
Detroit speed rear 2’ drop springs in back
Urethane bushings
All new GM glass
$26000.00
Oshkosh Wi
920-427-1373
