Welder opinion
looking at a Horbart Beta Mig 250 for $700 he will through in a Hobart 165 plasma. Is this a good welder? The plasma he said need a little work. Just learning to weld and don't want to mess around with junk. welder comes with tank/gun. Basically working on cars is the plan is, house hold stuff. Any opinion will be appreciated.
Thanks Kirk |
If the welder is in good working condition that is a screamin deal. That sells for around $1200 - $1500.
Purchased the welder
Well today I went and picked upthe welder,and the the plasma, It was a Semi truck autobody shop that owner got fed up with employee's and closed shop. Turns out the plasma is a 625 forced air plasma. I don't need this so it's probably up for sale,
send it to me I'll pay shipping :D
Orangevert....
Why would you want to get rid of a perfectly good plasma cutter.... Dude! This thing will cut "UP TO" 1/2 steel (it's rated at that which means it will do it - but trust me - BARELY is a better description) It will run on a 40 amp 12oV circuit - and doesn't require that much air pressure of CFM. If you have a decent compressor - you've got a nice cutting tool here. By the way -- it's not a "forced air" --- it's a Hobart AIR FORCE 625 |
| All times are GMT -7. The time now is 08:26 AM. |
