Baer brakes front track system 1970-81 camaro
Baer brakes front pbr 2 piston aluminum calipers, 13" one piece rotors, slotted/drilled/zinc coated, aluminum hub mounted on bell 2" drop spindles, proportioning valve & master cyclinder (not pictured), never installed. $1425.00 plus shipping
http://i815.photobucket.com/albums/z...h_101_0197.jpg |
Do you know if these change the track width?
As far as I know these are a direct replacement, same track width. When I originaly ordered them the only thing the rep. @ Baer told me was that I would have to use @ least a 17" wheel. I purchased them for my 1971 Camaro.
Tim |
