| aronhk_md |
06-25-2010 05:30 PM |
79 Camaro 10 bolt 8.5 rear factory 3.73 posi - Delaware
Its a 79 Camaro 3.73 rear that was bolted in my 73 trans am, and the previous owner believes he changed u-joints to fit the early 2nd gen bird, and I believe that later 2nd gen bird and camaro GM got smart and made identical. Overall, if you are interested make sure you do your research to see what if anything needs to be changed.
This rear has NO problems, and made no odd noises. ONLY reason I am selling it is I have another rear with 3.08 gears and disc brake conversion going in. My turbo car will prefer the taller gears. No sense pulling apart this good rear to do it.
The rear is still installed in the car at the moment, but I'll be pulling it any time now. It includes the drum brake setup which needs a new right side brake cylinder. Its just not pushing as hard as the other side. Otherwise pads and drums are all good. Posi works fine. Also pretty clean and painted black, but not showcar ready. Its a bolt in deal.
$400 in Laurel, DE 19956
