| jjarky |
07-03-2010 11:29 AM |
LS1 stand alone harness 4l60e drive by wire dbw obd2
SOLD
Stand alone harness for an LS1. Set up for drive by wire and 4l60e. Should work with LS1 from 97-04 that is dbw. I had the harness professionally re-worked for stand alone operation. Basically a 3 wire hookup, power/ground and switch. Relays for fuel pump, injectors and dual fans. All fused with standard spade fuses. Everything is labeled and ready to plug in. As you can see from the pics, all connectors are in excellent condition.
I had this harness done before I purchased an engine. The engine I purchased came with a harness so this is an extra.
Currently on ebay. $300. Will take $325 shipped to end auction now.
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Thanks.
