Ny-Trex Nitrous Systems
3 Attachment(s)
Ny-Trex Bare-Bones Nitrous Systems http://www.xplosiveperformance.com/N...s-_p_1787.html Attachment 25754 Bare-Bones Nitrous Systems use top quality components with an emphasis on performance and price. These Ny-Trex Systems have many of the great features offered in our top line systems and have been thoroughly dyno-tested on numerous vehicles to insure the most safe and reliable performance possible at any price. Bare-Bones EFI Economy Wet Nitrous System uses the Raptor wet Nozzle (up to 175hp) Bare-Bones Economy Carb Plate System uses the Bare-Bones 4150 plate (up to 200hp) Each Complete Bare Bones Systems Include: Adjustable HP jetting 10 lb Wet-Black powder coated bottle Hi-Flo 660 bottle valve Bottle brackets Braided stainless lines Switch controls, clamps, fittings & hose Brackets, hardware, bolts Easy “Step-By-Step” instruction sheet Lifetime Warranty on solenoids Ny-Trex 8 cyl EFI Wet Nitrous Kit http://www.xplosiveperformance.com/N...t-_p_1786.html Attachment 25755 Ny-trex is proud to offer the all new EFI 4, 6 and 8 cylinder wet nitrous systems. Ny-Trex EFI wet nitrous systems use only the highest quality materials and components to produce the best performing, best looking and most reliable wet system around. Ny-Trex systems have been throughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible. Complete Systems Include: 10 lb Wet-Black powder coated bottle Chrome Hi-Flo 660 bottle valve with gauge port Braided stainless N2O feed line w/Tefl on core 22”x-3 braided stainless nozzle lines, 1 blue, 1 red T-Rex Nozzle* & adapter (up to 300+HP) Adjustable HP jetting 15A WOT micro switch Quick-Clamp stainless bottle brackets Mounting hardware, brackets, bolts, screws, clamps, ties Electrical components, wire connectors, relays, switches Drill & tap, fittings, sealant Hot-Shot N2O & fuel valves Lifetime warranty on solenoids Special Features Exclusive T-Rex Nozzle* with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering only 35 HP. Nozzle has unique faceted spray tip to pass air around the nozzle without disrupting the spray pattern. T-Rex is the highest fl owing nozzle available with .110 fuel and nitrous passages that can deliver over 300 hp with a single nozzle. Flow matched fittings allow for the use of any style flare jets that are currently used in the industry. Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts. Plungers are made of high grade alloy with greater tolerances to prevent sticking. The N2O seal is Tefl on and a special Viton seal is used for fuel. Dual Taper Jets provide a consistent fl ow of nitrous and fuel and come in a large array of sizes. Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide. Triple-Threat™ V-8 EFI Wet Nitrous System by Nytrex Attachment 25756 http://www.xplosiveperformance.com/T...ex_p_1782.html Ny-Trex is proud to introduce the next phase of nitrous innovation, the Triple-Threat™ wet nitrous system. This system combines all three valve functions: Purge, N20 and fuel in one easy to install component. The Triple-Threat™ is a precision machined billet body with three integral solenoid valves with Volt-Trap coils for a dependable, clean, all-in-one nitrous system. Ny-Trex nitrous systems use only the highest quality materials and components to produce the best looking, best performing and most reliable wet system around. Ny-Trex exclusive Triple-Threat™ systems have been thoroughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible. Complete Systems Include: 10 lb Wet-Black powder coated bottle Liquid Filled Bottle Gauge Fuel Pressure Safety Switch Complete Purge System with V-Spray Chrome 660 Hi-Flo valve with gauge port Braided stainless N2O feed line w/Teflon core 22”x-3 braided stainless nozzle lines, 1 blue, 1 red T-Rex Nozzle & adapter (up to 300+HP) Adjustable HP jetting 15A WOT micro switch Quick-Clamp stainless bottle brackets Mounting hardware, brackets, bolts, screws, clamps, ties Electrical components, wire connectors, relays, switches Drill & tap, fittings, sealant Triple-Threat™ Valve w/Lifetime Warranty Special Features Exclusive T-Rex Nozzle with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering as low as 35 HP. Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts. Plungers are made of high grade alloy with greater tolerances to prevent sticking. The N2O seal is Teflon and a special Viton seal is used for fuel. Dual Taper Jets provide a consistent flow of nitrous and fuel and come in a large array of sizes. Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide. For You Mustang Guys Check this beauty out http://www.xplosiveperformance.com/T...em_p_1636.html Call our TOLL FREE NUMBER or PM us for ADDITIONAL SAVINGS THIS MONTH 888.493.8041 |
| All times are GMT -7. The time now is 05:29 AM. |
