-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   will this pan work?? (https://www.lateral-g.net/forums/showthread.php?t=28063)
aany001 08-08-2010 07:18 PM
Guys I was wondering will a LS Hummer oil pan have enough clearance for my LS1 swap in my 69 camaro with a stock frame and with a unisteer rack??
SLO 65 08-08-2010 07:27 PM
There's a good "sticky" on LS1 Tech in the Hybrid/Conversion section that has all of the dimensions for the different LSx pans. The Hummer pan is 7.5" deep vs. 5" for the F-body and LS2/3 Corvette pans. I don't know if either will clear the rack.
Nick
ProdigyCustoms 08-08-2010 07:40 PM
They are dangously deep and serious threat of high centering
aany001 08-08-2010 07:43 PM
just went to the garage and compared the measurements to my 96 chevy small block's oil pan that was in the car with the rack and the measurements are almost identical.Looks like it will fit perfectly without any mods.Heres hoping and will let you know this sat when my new drivetrain arrives.Anyone knows if the dimensions of a conventional chevy small block are similar to the LS1 as in where they sit in the frame??? If they are close this will work.I had tons of room with my old engine in there!!!:_paranoid
aany001 08-08-2010 07:44 PM
Sorry Frank what do you mean? Are you meaning ground clearance will be an issue??
aany001 08-08-2010 07:47 PM
I was talking about the 2008 H3 Hummer pan.
aany001 08-13-2010 05:07 PM
anyone else run this pan and worked for them?
ProdigyCustoms 08-13-2010 05:47 PM
Yes, that pan will hang over a inch lower the the engine crossmember which is a disaster looking for a place to happen
dhutton 08-13-2010 06:21 PM
http://www.pro-touring.com/forum/sho...hlight=brp+pan
I think that is just about one of the worst pans you can use in a first gen.
Don
aany001 08-13-2010 08:41 PM
Ah man I installed the engine and ya it sits way too low for me.Also the pan hits the crossmember and wont allow one of the engine mount thriugh bolts to line up.Back to the drawing board..........:mad:
Thanks for all the input guys and anyone know of the best pan to use on a tight budget?? I have access to a buddy that has tons of different LS series pans and a fabricator to message them as required.
