-   -   will these lowereing blocks work with my setup (https://www.lateral-g.net/forums/showthread.php?t=28111)
speedshftr 08-10-2010 07:39 PM
i have a 68 camaro with a mono leaf rear.it needs about 3 inches lowered in the rear.the car is a slow cruiser and not a high hp car.i need inexpensive fix to get the rear down.will thse work for my setup.im running 18 inch rushforths also.
http://cgi.ebay.com/ebaymotors/67-68...-/300314913046
MarkM66 08-12-2010 12:57 PM
I would think so.
deuce_454 08-12-2010 02:13 PM
lowering blocks cause spring wrap... uou need to install some sort of under or overrider tractionbars if you expect it to behave nicely with tall lowering blocks and full throttle/braking..
but yes they will work
redfire69 08-13-2010 04:48 AM
I posted this over a p/t, your car is turning out so nice, I would spend the extra cash and go w DSE 3 inch lowering springs and a multi-leaf conversion. Good luck-
TA219 08-13-2010 07:38 AM
I put some blocks under my car because even with Hotchkis lowering springs the rear was up pretty high (until the leaf springs settle in) but I found some at my local autozone that were much cheaper
