700r4 for sale - Chicago, IL
$1250 built with the best parts and a very reputable builder in Dallas, TX, Sullivan Motorsports, never been run, here are the specs:
700r4 Transmission built by Sullivan Motorsports in Dallas, TX - 700 rev. boost valve kit .283 - 700 TB plunger valve spring - TV plunger kit high perf - 700 boost valve kit w/o-rings - 700 4th gear super hold servo - 700 2nd apply serv kit - 700 2-4 hvy duty kevlar band - 350-700r4 rear tall sprag - piston, 700r4 1-2 - pin kit fwd. acc - the beast shell - 4l60 filter - overhaul kit, super w/z-pak - 4l60 pump w/rotor & vane kit - thrust washer kit - bearing kit - 4l60 bushing kit - 4l60 shift kit - 5-pinion front planetary - 5-pinion rear planetary - front sprag w/race Additional parts from www.700r4.com - lockup wiring kit - TV cable setup for Holley 950 commander (can be adapted to other vehicles) Torque converter - Rebuilt production corvette lockup converter |
| All times are GMT -7. The time now is 05:58 AM. |
