FS 2002 Z06 Procharged
SOLD
With work being the way it is now I am never home anymore to enjoy the car. So instead of having the car sit I figured it is best to sell the car. 2002 Z06 Black Black Interior 74062 miles Located in San Antonio, Tx Performance -TSP MS4 Cam/Springs -90mm Intake & Throttle Body -60lb injectors -8-rib kit -Procharger F1C -Kooks Headers -Catless X-pipe -B&B exhaust -2-bar SD tune -160 T-stat -Oil Catch Can -Breather setup -Alky Control Meth Injection -Dallas Performance Dual Stainless Injection Setup -Tial 50mm Blow Off Valve -Restrictor Plate -Lonnies Dual fuel pump setup including Racetronix plug and play wire harness drain kit. -Spec Stage 3+ Clutch -Kirban Shifter Exterior -Racemesh Grilles -Taillight seals -20% Tint -Clear Corners -Shorty Antenna Interior -2Din Pioneer Head unit, DVD, Touchscreen -JL 500/1 Amp -JL Stealth Subwoofer Setup -Pillar mounted boost gauge -Pillar mounted wideband & fuel pressure gauge, Includes LED light that comes on when Meth is being sprayed. -Trunk Partition -Raptor shift light -Delrin Shift knob Other -Nitto 555R drag radials -Nitto 555 In front -Optima Red top battery Motor and Procharger oil changed every 3k. Very conservative tune. Restrictor plate installed to 613rwhp/540rwtq. Car gets 25+mpg highway. Only issue is 1st gear syncro is causing occasional grinding. Not interested in any trades. $24k Firm, will include: Factory TI exhaust, and C6 Z51 Sway bars http://i168.photobucket.com/albums/u...6/IMG_2760.jpg http://i168.photobucket.com/albums/u...6/IMG_2761.jpg http://i168.photobucket.com/albums/u...6/IMG_2762.jpg http://i168.photobucket.com/albums/u...6/IMG_2763.jpg http://i168.photobucket.com/albums/u...6/IMG_2765.jpg http://i168.photobucket.com/albums/u...6/IMG_2766.jpg |
Nice car.
Good luck with the sale. :thumbsup: |
That looks like a nasty little sleeper...good luck with the sale
Thanks. It definitely looks stock, but that procharger screams.
Ever race your neibhor with the white stang looks like a saleen
still available OBO
Have you tried posting it on digitalcorvettes.com?
Good luck!:thumbsup: |
I do now. Thanks:cheers:
sold!
| All times are GMT -7. The time now is 02:56 PM. |
