Misc SBC Stuff.....AFR, Jesel, Stahl, etc
Found water in #4 cylinder.....car never raced this way....only started in garage....going a different direction now....all parts except heads (bought used) have <10 passes on them.......
AFR 220 Non-Eliminator; Extensive port work everywhere....will make a lot of power...triple springs...probably need freshened...$800 Jesel #365050 Sportsman Rockers for Non-Eliminator AFR heads. 1.5 and 1.5.....$750 Stahl 2 to 2-1/8" stepped Fenderwell headers for 62-67 Nova....Stahl bolt patter....adapter plates included.....black.....$750 Scat 4340 3.48 Stroke Crank.....might be able to polish.....$300 Childs and Albert 6.0" Trackmaster I-beam rods....rated to 750 HP.....$150 Probe Pistons #17320....4.060"...3.5cc Dome....still on rods above....$150 Edelbrock Victor Jr 2975.....only work done is to match to heads....$150 Schneider Mechanical Roller Lifters Qty 7 + 1 Comp Cam Lifter......$150 Comp Cams 12-908-9 Solid Roller Camshaft....0.630 lift with 1.5 rocker....see Comp site for specs.....$125 HVH Super Sucker 2" Aluminum Spacer....$90 Trickflow Pushrods 7.750" length 0.080" thickness......$50 |
| All times are GMT -7. The time now is 08:46 PM. |
