-   Supporting Vendor Group Purchases (https://www.lateral-g.net/forums/forumdisplay.php?f=17)
-   -   Baer Brake Specials - WILL NOT BE UNDERSOLD! (https://www.lateral-g.net/forums/showthread.php?t=28738)
MCB Matt 09-29-2010 02:46 PM
As one of Baer Brakes TOP US warehouse distributors we would like to offer some special Lateral-G pricing! If you have a specific part# please include that in your PM or Email
Please PM for pricing.....Too low to advertise here!
Contact us toll free 866-MattsGM (866-628-8746)
Track-4 Features
•Systems contain all necessary mounting brackets and hardware, and even come with stainless steel braided hoses where required.
•Early domestic Muscle Car applications also include 6061-t6 billet aluminum hubs, pre-packed in Redline synthetic grease for a mess free installation!
•All components meet DOT specifications and are street legal in all 50 states.
•The 6-bolt architecture of the T-series two-piece caliper body produces an incredibly stiff caliper, netting incredible power and control!
•Stainless steel pad abutments which can be easily serviced when replacing the pads also serve as anti-rattle/noise shims.
•Track-4 systems are Street and Track ready and include Baer’s DecelaPad brand, Ceramic compound brake pad, offering quiet, low dust operation, with thermal stability up to 1385 deg. F!
•Pads are the same fitment as found on 1998-2002 Chevrolet Camaro (FMSI #D749). Never again will you be left stranded because you couldn’t find pads! It also means that you will no longer be “locked in” to an undesirable pad compound simply because replacement pads are only available from the caliper manufacturer!
•Features internal fluid transfer passages and are bolted together from the back half of the caliper. This arrangement makes the exterior of the T-series ultra clean with no externally visible crossovers or bleeder.
•Since there is only a single bleeder, located on the inner half of the caliper, the T4 calipers bleed quickly and easily.
http://mattsclassicbowties.com/t4 small.jpg
http://mattsclassicbowties.com/t4 caliper.bmp
