TCI - 6X - 6 speed Auto Tranny Specials
We are now a factory direct dealer for TCI transmissions! We have sold Three of these kits in the last 2 weeks and would like to offer a special for forum members!
Example: part# 271600P with paddle shifter $5500 shipped to the 48 states (Ca residents add 9.75% tax) http://static.summitracing.com/globa...CI-271600P.jpg This kit is also avail for gm LS motors, mopar and fords! Using the latest developments in drivetrain technology, TCI® has developed an innovative automatic transmission for Pro Touring, street and all-out race vehicles. Designed for GM applications, this 4L80E-based TCI® 6x Six-Speed Automatic Transmission is a fully programmable transmission that gives you six forward gears (2.97, 2.23, 1.57, 1.18, 1.00, 0.75) for quicker acceleration and increased fuel economy at cruising speeds. Capable of handling up to 850 horsepower, this versatile transmission from TCI® features a compact design, allowing it to work in a variety of performance applications. When used with the included EZ-TCU™ for shift point programming and the TCI® Paddle Shifter, or the optional Outlaw™ 2-Button Shifter set up for manual mode gear selection, this automatic transmission gives vehicles the most functional and modern drivetrain combination on the market. To ensure durability, TCI® engineers run each transmission across a computer-controlled transmission dyno to ensure proper line pressures and top notch transmission performance. Proof of this triple testing process is included with each transmission, shipped in the form of individual serialized spec sheets containing test scores. In addition, each TCI® transmission utilizes the patented HDT Coating™ for cooler operating temperatures and improved drivetrain efficiency. Six forward gears & fully programmable automatic or manual shifting for improved acceleration & fuel economy at cruising speeds TCI® EZ-TCU™ transmission control unit & 4-speed automatic shifter (ratchet, gate or stock) needed for standard automatic operation Full manual shifting with the 6x Six-Speed requires included TCI® Paddle Shifter or optional Outlaw™ 2-Button Shifter Self-contained design using 4L80E case eliminates clearance problems of external bolt-on overdrives Package includes transmission with bellhousing, EZ-TCU™ transmission control unit, TCI® Paddle Shifter, wiring harness, transmission cooler, dipstick & Max Shift™ Street Performance Transmission Fluid |
| All times are GMT -7. The time now is 07:12 AM. |
