-   -   700r4 - All the best parts - never ran (https://www.lateral-g.net/forums/showthread.php?t=29057)
steinepstein 10-21-2010 06:49 AM
1 Attachment(s)
$1250 + ship. I have a pallet ready to go and will wrap it up nicely, about $200 to ship.
700r4 Transmission built by Sullivan Motorsports in Dallas, TX
- 700 rev. boost valve kit .283
- 700 TB plunger valve spring
- TV plunger kit high perf
- 700 boost valve kit w/o-rings
- 700 4th gear super hold servo
- 700 2nd apply serv kit
- 700 2-4 hvy duty kevlar band
- 350-700r4 rear tall sprag
- piston, 700r4 1-2
- pin kit fwd. acc
- the beast shell
- 4l60 filter
- overhaul kit, super w/z-pak
- 4l60 pump w/rotor & vane kit
- thrust washer kit
- bearing kit
- 4l60 bushing kit
- 4l60 shift kit
- 5-pinion front planetary
- 5-pinion rear planetary
- front sprag w/race
Additional parts from www.700r4.com
- lockup wiring kit
- TV cable setup for Holley 950 commander (can be adapted to other vehicles)
Torque converter
- Rebuilt production corvette lockup converter
73RSZ/28 03-29-2011 06:44 AM
Still available? What is the stall on the convertor?
steinepstein 03-29-2011 03:35 PM
Yes, still available. I don't have the exact stall, I took a brief look on the interwebs for "corvette 700r4 converter stall" and got 1400, I will go get the part number if you are interested.
Thanks,
Jon
