-   -   350 crate motor (https://www.lateral-g.net/forums/showthread.php?t=29360)
hotrod69camaro 11-11-2010 08:22 PM
350 crate motor
4 Attachment(s)
350 chevy crate engine. I bought this new in 2001. Has 6000 miles. This motor is removed from my 69 camaro. Vortec heads 9.1 to 1 compression. Forged crank, powered metal rods. This was a 330 hp motor from chevy. Has a hydraulic Comp cams XE262 cam. Nothing radical. Sound nice and has a little lope at idle. Melling oil pump and Milodon pan and pickup. Comp cams 2 piece timing cover. Comp cams timing chain and gears, with thrust button and torrington bearing. edelbrock street fuel pump, Holley HP series 650 carb. MSD pro billet distributor, includes starter and flex plate. This motor was dyno'ed after break in on the chassis dyno at Superior automotive in Anahiem CA on 4/20/02. It makes 370 horsepower at 5400 RPM. (I have the dyno sheet). This motor runs Royal Purple synthetic oil. This is a good street motor, runs and idles well. No smoke.1400.00 OBO Call Mike (714) 901-8781 SOLD SOLD
tommycomfort 11-12-2010 11:37 AM
What kind of torque numbers on the dyno?
Thanks,
Tom
GM Muscle 11-14-2010 02:47 PM
Pm sent
SLO_Z28 11-14-2010 05:14 PM
Thanks,
Tom
Ive built this engine before and got a solid 400# for a long flat RPM range, an amazing street engine. This is a great deal too.
SWAPMEETCRAZY 11-15-2010 04:22 PM
pm sent--jim
