-   -   Street rod garage full frame (https://www.lateral-g.net/forums/showthread.php?t=29389)
snappytravis 11-13-2010 05:53 PM
So just looking for some opinions on the full frame cars versus, dse setup, I personally would think you could get a much more rigid chassis with the full frame, If I recall street rod garage frame is suspose to be bolt in for the most part. I would like to know if anyone has this chassis compared to the Morrison set up, that you have to cut the floor out of the car. I am planning on running the 345 rear tires and already did the mini tubs. thanks for your input
deuce_454 11-14-2010 04:22 AM
depends...
one is bolt in.. the other requires you redo the whole underside of the car.. in my view it is questionable if the car retains its identity at all.. i mean if you put a camaro on a 4x4 blaser frame, wiuld it be a camaro body in a blaser.. or a 4x4 camaro??
so will it be a 2010 art morrison supercar with a camaro body??
anyway enough with the ranting..
subframeconectors and solid bodymounts wil be as rigis as the full frame... and the frame is a bracket to hold the suspension.. so a frame that doesnt change geometry (=accepts stock geometry suspension ) will do zero for the handling
an ATS chicayne kit on a stock subframe will perform as well as a DSE one or within a few % of it.. and cost 6 grand less...
if it were me id call marcus at SC&C and have a talk about options before comitting to insanely expensive suspension stuff, more wisely spent on engine and brakes.. and paint.. and fasteners.. and interior.. and A/C and carbonfibre hoods and so on and so forth....
