-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   ram flywheel (https://www.lateral-g.net/forums/showthread.php?t=29440)
GM Muscle 11-16-2010 06:18 PM
ram flywheel
Im getting ready to do an ls1 t56 swap on my sbc. i probably make 350hp at the flywheel.
ive been looking at flywheels and see that ram sells a billet flywheel for roughly $100 cheaper than mcleod or centerforce. Is anyone using the ram billet flywheel?
http://www.jegs.com/i/Ram-Clutches/7...oductId=751484
any opinions/suggestions?
funcars 11-16-2010 09:14 PM
My .02:
I have a RAM Al flywheel and use their long p-plate and 6 puck disc in my Ford motor. Quality seems as good as anything I've used in my Fords or Chevys. I'd still balance the flywheel and clutch together for a neutral balance motor if it sees high rpms.
GM Muscle 11-17-2010 05:32 AM
6k rpm at the most
