1969 Firebird Convertible Tribute TA
1969 Firebird Tribute TA Convertible asking $40,000.00
White and silver/gray TA paint scheme Not a real TA. Car runs great and gets lots of attention but it is time to move on to another project. The car gets driven quite a bit. It is not a trailer queen and is enjoyed whenever we decide to not just weekends. Not the original Motor, but is a healthy 400 with a 4 speed Manual trans (not sure if M-21 or 22) Great condition convertible white top with silver/gray piping that matches the silver/gray TA stripes One Power top cylinder needs to be rebuilt, the power top switch needs to be installed. The top worked 1 time after I got it and I heard fluid bubbling out the top seal of the cylinder on the driver side. Billet Specialties Wheels 16x7 front and 17x8 rear Model Fast Lane with Khumo Tires AfterMarket Fiberglass TA hood Window tint legal for Texas and had rear view mirror done since the plastic back window could not be. Body Tag info ST 69 22367 LOR524372 BDY TR 208 52-B PN 12-C Custom interrior includes Black and Silver theme Covans Thunder Dash with Autometer Electric Guages of the Ultra-Lite II series Vintage Air A/C with Billet Knob Controls and it blows cold air Custom steering wheel that matches in interior but I have no idea what it originally came out of. Engine 400 YC 001739 stamping in the front and Distributor Pad G067 Heads have 13 stamping Unknown Cam brand and specs but not a stock cam Unknown engine internals Chrome Valve covers MSD 6AL ignition box plus MSD Distributor Most of the below has been done since mid May of 2010(including brakes and suspension) Edelbrock Intake Holley 750 Vac Secondary carb w/ electric choke K&N Air Cleaner with Xtreme Air Lid plus Valve cover breather Doug Thorley Headers that are PermTex Coated 160 High flow T-Stat 185 Fan Temp Switch March Performance Pulley Serpatine Belt Kit which includes: *140 Amp Alternator *Edelbrock reverse rotation water pump *Power steering pump with Billet Specialties Black remote resavior. *Goodyear Gatorback Belt Remote Oil Filter relocation and oil cooler Lincoln or Ford High Speed Electric Fan New starter with less then 100 miles New Battery within the last 2 months New hoses and radiator cap Brakes Wilwood Disk 4 piston on all 4 corners Fat Boy Master Cylinder 1 1/8” Bore Polished dual 8 inch Brake booster Have Emergency Brake kit but not installed yet All new Brake lines done when the wilwoods were add about 300 miles ago. Wilwood proportionating valve added to rear brake lines Suspension Upper and Lower tubular Control Arms Del-rim or Del-lum bushings QA1 adjustable coil over front shocks with 550lb springs GMP-1550 QA1 Adjustable rear shocks Multileaf 1 1/2-2 inch drop leaf springs Energy Suspension shackle bushings in rear Energy suspension front sway bar bushings and end links Hotchkis Subframe connectors New in the Box with all hardware and rear body mount bushing. These have not been install yet but plans are to get them installed if car does not sell prior. A set of Marquez Billet Tail light Lens and Spaghetti Engineering LED Digi-tail lights with new tail light len seals waiting to be installed. Lower baffle panel needing cleaned up and painted then installed Front eye leaf spring bushings from Energy suspension waiting to be installed but not a must do I probably have left something off the list but did try to list everything about the car I can think of at the moment. The only thing I will consider for trade is a 2006-07 Lemans Blue Z06 with the 2LZ package. First picture show the current wheels and ride height. Other pictures are of the car when I got it. A link to the entire photobucket album is here http://s170.photobucket.com/albums/u...69%20Firebird/ http://i170.photobucket.com/albums/u...d/DSCN0921.jpg http://i170.photobucket.com/albums/u...d/DSCN0287.jpg |
Very nice. Looks sharp.
Good luck!:thumbsup: |
bump to the top
| All times are GMT -7. The time now is 01:53 AM. |
