World Warhawk LS1x / TEA hand finished Heads
http://i55.tinypic.com/rlml5i.jpg
http://i52.tinypic.com/o555og.jpg http://i56.tinypic.com/25jz7lz.jpg http://i54.tinypic.com/245mwwg.jpg These are World Warhawk LS1X heads that have been worked over by Brian Tooley at TEA. These are the perfect HUGE horsepower platform. 3/4" deck thickness!!! Factory Specs : World Part # 025250-3. Casting ID Number: WOR-075 Material: 355-T6 alloy high density aluminum Valve Seats: Intake (hardened), exhaust (hardened) Valve Guides: Manganese bronze Spring Seats: Machined for 1.560" Valves: Manley stainless steel valves in assemblies Valve Diameter: 2.080" intake, 1.600" exhaust (5/16" stem) as cast Rocker Arms: Stock LS1 with stock stands Intake Runner: 235cc, standard port location Exhaust Ports: 87cc, standard location Combustion Chamber: 72cc Spark Plug: 14mm .750" reach gasket style Valve Job: Multi-angle intake and radiused exhaust Valve Cover Rail: Raised .300" for aftermarket valvetrain Valve Angle: Stock 15° 1.550" dual springs, Solid Roller, Spring Specs: 1.550": 200 lbs. @ 1.900", 480 lbs. @ 1.200", coil bind @ 1.150", max lift @ .700" See TEA Invoice above... TEA then took the heads and performed the following: Valve job Set spring heights, machine spring pockets Hand finish the chambers, and all ports Machined the pushrod holes for 3/8" pushrods Clearanced the upper valvecover rail for shaft mount Jesel rockers Flow the heads Total labor : 847$ Flow numbers: In. Ex 0.1000 70.6 60.1 0.2000 151.5 126.8 0.3000 222.2 190.0 0.4000 276.9 230.6 0.5000 313.6 256.0 0.6000 329.7 268.2 0.7000 321.7 274.2 0.8000 327.7 280.3 SOLD |
offers?
Heads
I'm building a 402 Do you think these would work? From what I've been reading they might be a little big. This is going to be a street motor for my 69.
They would work out great on your motor. I actually wouldnt go with anything smaller than a 225cc intake runner on that motor size, and 235's just give you a little more room for a larger cam to grow in to
Price lowered to 1875
Sold...
| All times are GMT -7. The time now is 04:46 AM. |
