-   -   2000 camaro 4l60e painless harness ecm (https://www.lateral-g.net/forums/showthread.php?t=29677)
ivmotor 12-02-2010 03:12 PM
2000 camaro ls1 4l60e painless harness ecm
Complete engine and trans ready to run, bought for a conversion and economic times reversed the install. Computer is already converted to "hot rod" so codes for smog have been removed. Antitheft is also gone. All accesories as well as new belts, tensioner and conversion mounts are with it. Engine was installed, tuned, then removed so we know everything is perfect. $4000 plus the ride. I can do pics if you want them.
Ishmael 12-02-2010 06:55 PM
How many miles on the engine and are headers included? Drive by wire or cable? Sounds like a fantastic deal.
ivmotor 12-02-2010 08:45 PM
It has oem manifolds and headpipes. It is throttle cable operated. Mileage from sales receipt showed 42k, but I didn't verify in person. Engine is very clean under the valve covers and trans fluid was still pink in the pan. All accessories are F-body so you will have to notch if its going into an earlier car. I do sell mounting brackets to tuck accessories in, I will get a pic of both sets of brackets for you.
ivmotor 12-13-2010 09:27 AM
engine for sale and our preferred bracket arrangement
http://i659.photobucket.com/albums/u...DSCF2224-1.jpg
http://i659.photobucket.com/albums/u...DSCF2222-1.jpg
The engine is complete as a changeover, harness is painless, ecm is ready to run. All sensors, adapters, etc come with this assembly.
