1967 RS Camaro for sale
5 Attachment(s)
This is not a completed project, but well on it`s way in being one. I have a bunch of goodies for this car. Just about everything for this car is brand new or restored. I`ll give a few details of the car right now and will update more as soon as I can get some better pictures of the car.
It has NOS quarter panels replaced New trunk lid Original rust free GM doors Original rust free GM fenders with patches in the bottom corners USA made floor pans buttwelded in Center trunk pan replaced Rear window filler replaced Original GM tail panel Original GM rockers Original roof panel New dash top USA made toe boards replaced buttwelded NOS outer wheel houses replaced USA made passenger inner wheel house and shocktower area replaced 12 bolt with GM 3.73 gear, Eaton posi, new bearings, moser axles, moser pinion yoke, aluminum diff cover New stock gas tank AAW full classic update wiring harness with RS front harness GM RS headlights fully restored with new motors All factory trim 15x7 GM ralley`s restored with BFG 235, 255 with new chrome New deluxe door panels All original glass Factory tilt wheel column Front seats, needing resto...have a few parts for them though as well as rear fold down seat Also, 2001 Trans Am leather power seats front and rear New SS fuel, brake lines and trans lines 76 Corvette rotors, 76 GM truck calipers, modified 69 camaro brackets front brakes...stock drums for rear...Do have an LS1 front and rear brakes Front subframe from 68 camaro welded seams and removed upper a-arm bracket to do GMod...have original frame as well in good shape All new tierods, HD centerlink, pitman arm, original power box Bunch of extra odd and end stuff to go with the car as well All new bolts All new Hotchkis springs front and rear with Poly bushings, motor and trans mount poly too DSE Subframe connectors, in process of installing Smoothed firewall, in process of completing Rough body work completed 1997 4L60E auto transmission completely built with all upgraded parts and Transgo HD2 kit, B&M trans cooler, PI Vigilante 2800 RPM stall and Spicer 1350 tailshaft, painted red with Polished aluminum pan...0 miles...all parts new Brand new GM 4 bolt main one pc rear main 350 roller block, roller lifter spider, Edelbrock 2pc aluminum timing cover, Kevco oil pan and matching oil pickup. Melodon Z28 oil pump, All polished stainless steel ARP bolts, ARP head and main bolts, 6 3/4" SFI internal balance balancer, Eagle 4340 forged steel 3.48" stroke crank, Eagle 5.7" H-beam rods, Ross Racing Forged pistons with plasmamoly rings, polished aluminum water pump, billet aluminum accessory mounts, Prothane Poly motor and trans mounts...all items are new....Comp cams 282S cam and lifters, used, matching Comp Cams springs, new, Comp Cams 10 degree Titanium retainers, Chromoly locks and Viton seals, new...Edelbrock Performer RPM manifold, used and BG 650 double pumper, used New TH400 trans crossmember No hood, spoiler or inner fenders and no driveshaft Bolero red code with black deluxe interior, added fold down rear seat Tons of boxes of new misc. parts...too much to list NO TRADES $14,500 Fairly FIRM....serious inquiries only please and will provide my # to those seriously interested |
| All times are GMT -7. The time now is 01:53 AM. |
