Painless wiring hints
I am trying to get the wiring going and wanted to see if anyone has some pictures of their wiring.
i didn't use painless stuff but the best tip is mount everything you want to use where you want it and then wire to it. then you know if you need longer wires of how much to shorten wires.
i also don't like to use butt connectors. i solder and heat shrink everything. make sure that you do it in a place that doesn't move around at all and isn't in a bend so the wires don't break over time. zip tie everything as you go to keep it clean and out of the way then when your done wrap it in black tape and cut the zip ties off as you go. |
| All times are GMT -7. The time now is 05:49 AM. |
