Which One-Piece Floor Pan
I will be replacing the floorpan and the trunk pan on my 68 Camaro. My truck pan has a lot of pin holes in the center and crunched in the driver side which is why it will be replaced, the floor is flinstone status. I also need toeboards.
My question is one-piece floor pan is the best? or which companies should I avoid? I did a lot of searching and found more than plenty of information on how to do the install, now I just need to know where to buy Thanks for the Help! |
I have used a few of the dynacorn 1-piece floors and fit has always been good. Bel-air Bobs has been a good source for alot of the floorpans,side cowls, etc, I've needed for the camaro's projects we have done. Joe :thumbsup:
John, have you made a decision on a full floor?
I went with a full floor from Classic Industries. It looks good and my builder likes it but it's not in the car at the moment so I don't know what the fitment is. Other guys on here know more about this then I do so hopefully they will chime in and help you out. Thanks. |
Dynacorn here. Fit was good considering the tolerances of these cars. Not sure if others like Goodmark are actually the same source panel from overseas.
I used the Goodmark piece and it went in well with just a little stretching. I read about a one piece full floor, trunk and frame rails from Bel Air Bob's over on Camaros.net that sounded interesting but it was high $$$$.
I still haven't ordered anything I'm waiting until I'll be home for a little while should be ordering in the next few days or in a week
Thanks for all the input I'll do some more research and keep you posted on te outcome |
| All times are GMT -7. The time now is 03:42 PM. |
