ls1 style t56 to SBC "conversion"
Im going a different direction so here it is.
It's an LS1 style T56 from a 2002 trans am that was supposedly wrecked in 2004. I bought this on a pallet that was in a storage building and it has been visually inspected by a certified mechanic as well as by me. It shifts through all the gears fine and only has a small amount of fork material in the fluid which the mechanic assured me was perfectly normal. Heres what you get: -LS1 style t56 -621 Bellhousing with shift fork (original not repro) -Centerforce Dual friction clutch and pressure plate (about 2000 miles on it) -LS1 to Muncie adapter plate with extended throwout bearing -Complete Auto to manual swap for a 70 chevelle (will fit other years). This is the full conversion with pedals, bushing, linkages, boots. Literally everything you need to make your car a functioning manually shifted car. ( brand new) -Hurst billet shifter also a few parts that i dont need around -lt1 style pedal setup and a lt1 style crossmember What you will need to complete the swap: -Driveshaft -Pilot Bushing -Flywheel Im asking $1700 plus shipping. I located in Sherman, TX and might be willing to make a short drive if neccessary. |
:faint: |
Insult to injury..... We plan on going to Austin sometime in the next month! Haha |
i also have a drive shaft that i will throw in the deal that may be the right length but im not positive. i used it when i had a 700r4 in my car.
Pm or two sent
Sale pending
Sold!!!!
GM Muscle, Thanks again for the deal and for meeting me pretty much halfway.
no problem. hope you enjoy!
