Popular Hot Rodding Project Street Fighter Mustang For Sale ('66 Mustang)
Hey guys, it's time for the Mustang to find a new home. For those of you who haven't seen the car in PHR, it's been running in nearly every issue since November 2008. The car is ready to go! I recently had it aligned and corner weighted at Roger Kraus Racing in Castro Valley, CA. It runs and drives though there are a couple really small projects to finish, I may even get to them before it finds a new owner.
$25,000 OBO (preferably plus more than minus :P ) http://milesspeed.com/cl/stang12.jpg See all of the stories published so far (still more to come) http://www.milesspeed.com/fab/mustang.htm http://milesspeed.com/cl/stang2.jpg Specs 565 horsepower at 5,600rpm 564 ft-lbs torque at 4,600rpm Engine Type: 427-ci Windsor Block: Dart iron, splayed 4-bolt main caps Oiling: 7-quart Canton oil pan Rotating assembly: polished and chamfered 4340 forged steel crank, 6.2-inch forged H-beam rods, high silicon forged aluminum pistons Cylinder heads: Smeding designed AFR aluminum, CNC machined 205cc intake runners, 60cc chambers Camshaft: hydraulic roller, .544/.573-inch lift, 238/248-degrees duration at .050-inch lift, 110 lobe center Valvetrain: Scorpion 1.6:1 rockers, 2.08/1.60-inch valves Induction: Edelblock Victor Jr. intake, 850-cfm Mighty Demon with annular boosters Ignition: Smedding branded MSD Super Conductor wires and looms, Pertronix ready-to-run distributor Cooling: Be Cool radiator with dual Spal fans Fuel system: Rick’s Hot Rods fabricated stainless steel tank, AC Delco electric in-tank pump, Earl’s Pro-Lite hose and Ano-Tuff fittings, Aeromotive fuel pressure regulator Exhaust: Doug’s mid-length headers, 2.5-inch tubing, Flowmaster Super 44 mufflers Fasteners: ARP Drivetrain Transmission/shifter: Keisler T45RS 5-speed manual, hydraulic throughout bearing, Competition Specialties Stage 4 clutch, Keisler shifter lever Driveshaft: Steel custom length from Keisler Rear axle: Chassisworks Fab9 housing with Currie 3rd member, 3.25 gears, Detroit TrueTrac, 31-spline axles Chassis Front suspension: Total Control Products tubular upper and lower control arms, VariShock coilovers, power rack, 1 3/4-inch sway bar, big bearing spindles Rear suspension: Total Control Products G Bar canted 4-bar, VariShock coilovers, ¾-inch sway bar Brakes: Wilwood 13-inch rotors, 6- and 4-piston calipers, stainless braided lines, Wilwood dual reservoir master cylinder Interior Seats: Corbeau Forza seats and belts Dashboard: JME machined aluminum gauge pod and gauges Wiring: American Autowire Classic Update kit Column: Flaming River stainless tilt column, Grant wheel Body/paint Body: Fiberglass hood from NPD, body work performed at JCG Restorations, Oxnard, CA Paint: Summit Racing single stage Bright Orange Metallic and Medium Charcol Gray Metallic with lime green pinstripe Wheels/tires Wheels: Vintage Wheel Works V60, 17X8 Tires: BFG R1, 245/40R17 Liz Miles [email protected] Email or PM me if you have any questions! http://milesspeed.com/cl/stang11.jpg http://milesspeed.com/cl/stang10.jpg http://milesspeed.com/cl/stang9.jpg http://milesspeed.com/cl/stang8.jpg http://milesspeed.com/cl/stang7.jpg http://milesspeed.com/cl/stang6.jpg http://milesspeed.com/cl/stang5.jpg http://milesspeed.com/cl/stang4.jpg http://milesspeed.com/cl/stang3.jpg http://milesspeed.com/cl/stang1.jpg |
nice car Liz. We need a price. :)
Jody |
Hola Liz,
Hope you find a seller soon! But just so you know, I've been spreading the word for you. Btw, I didn't know you were a member here, are you on pro-touring.com? Hector |
DUH how could I forget that!
I've whittled my exceptions down to $25,000 Quote:
Bump for a fun car! :)
Looks like a great price for that car and all the things done to it ....GLWS
Seems like a lot of car for the money, good luck with the sale!
wow love the car, just need to sell mine first!
looks like I may have a buyer! I'll find out for sure tomorrow :)
| All times are GMT -7. The time now is 10:11 AM. |
