V10 Motor and Trans, NEW
O.K Guys, this is one awesome deal. Due to medical reasons it has to go.
This is a Gen 3 Viper motor is built and done right. This engine will make 650+ HP easy. This engine is spotless and never run in a car, as you can see by the pics no expense was spared. The valve covers on this motor alone cost over $1500. Thera re many one off Billet CNC items on this motor made by Deanz Rodz. I also have the 6 speed trans which is also built like a monster to handle over 1000HP. The trans was built by Rockland Standard gear in NY. This trans has been gone through and had thier "Transzilla JR" parts installed, a Quick time SFI bell housing, and Ram dual disk clutch, flywheel and slave along with a B&M short shifter. Trans has never been used. Fresh and ready to rock. may seperate. I have the headers avaliable as well if you would like to purchase them. Their desgin will allow them to work on most hot rods and other tight fitment cars. Made by "Stainless header MFG" Pefect welds and a killer collector desgin make these the best headers I have every seen. 1 3/4 tubes with laser cut flanges. Computer aid design says they add 80 HP over stock. This engine is a Monster Tourqe and equally impressive HP in an unforgetable visual package that will preform day after day after day. Quick run down: New Gen 3 viper engine (0 miles)-$ 13,000 Rolling Thunderz heads (stage 2 ported) and valve work.-$3700 Stainless Headers MFG custom 1-3/4 tube headers with killer merge collectors, 02 bungs. $3200 CompCams Custom grind roller cam springs retainers-$1100 Deanz csutom Thermostate housing (plus original that has been chromed)- $1200 Deanz custom power steering res- $600 March Billet pully kit-$450- (not pictured) Power force II SFI Damper-$300 Crower shaft mounter rockers-$1500 X-metal Billet "Big Mouth" single blade Throttle body-$350 X-metal Solid Billet valve covers- $1500 Extruda Body custom billet fuel rails -$600 MMS Stainless fastener hardware-$195 HotWire " Stand alone" wiring harness- also includes T56 Trans wiring harness-$750 (not pictured) Chrysler Specialties custom ECU-$350 (not pictured) Polished intake and Volant super flow air filter-$150 (Not Pictured) Custom racing spark plug wires and looms-$90 Fel-pro gaskets-$75 Polished Front Cover-$150 Deanz Oil relocation kit- $300 Professional product Filet Oil filter- $100 T-56 TRANSZILLA JR- $3900 (includes Trans) not pictured Quick Time SFI bellhousing Scatter Sheild- $550 Ram Dual Race clutch and flywheel- $1300 B&M Short Shifter (used)- $150 Thats $35,610 Best OFFER!!! HAVE MORE PICS!! http://i716.photobucket.com/albums/w...ithHeaders.jpg http://i716.photobucket.com/albums/w...almostDone.jpg http://i716.photobucket.com/albums/w...Thunderz10.jpg http://i716.photobucket.com/albums/w...gThunder12.jpg http://i716.photobucket.com/albums/w...waterneck1.jpg http://i716.photobucket.com/albums/w...alvecovers.jpg http://i716.photobucket.com/albums/w...rs4510/088.jpg http://i716.photobucket.com/albums/w...rs4510/082.jpg http://i716.photobucket.com/albums/w...essheader1.jpg |
| All times are GMT -7. The time now is 11:12 AM. |
