-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   Ringbrothers Touch Starter System (https://www.lateral-g.net/forums/showthread.php?t=31536)
Ringbrothers 04-15-2011 11:30 AM
This has to be one of the coolest products we have! The first ever touch start button. Touch not push. The button is touch sensitive with an interactive LED display.
Direct replacement for standard keyed ignitions.
Simulates five positions of keyed ignition: Off, Accessory, On, Crank and Run
All required wiring and connectors are included and no external relays required.
Made in the USA
Price: $650
Check out our website for more information
http://i656.photobucket.com/albums/u.../PushStart.jpg
pokey64 04-15-2011 12:51 PM
Have any video of starting a car with it?
Bakaruda 04-16-2011 07:35 PM
Definitely need more information please.
ErikLS2 04-17-2011 04:55 PM
Will this work with ISIS?
Ringbrothers 04-18-2011 07:59 AM
More details:
FIRST TOUCH: Simulates Accessory position turning on only consumers such as your radio to conserve energy and save sensitive components such as heated 02 sensors and engine computers. (which may suffer from being turned on unnecessarily)
SECOND TOUCH: Simulates On position which is typically connected to power windows, engine computer, gauges etc.
THIRD TOUCH: Simulates Off position.
• A push on the brake and momentary press on the switch engages the starter. Starter is automatically disengaged once “Ignitor” senses the engine running. A convenience found in many modern luxury vehicles.
• Another push at any time returns the ignition to an off state. It’s just that easy!
• Interactive built in led display allows for visual conformation of simulated key position. A theft deterrent pulsing red light when vehicle is off is included.
• Will accept input from any momentary switch, including popular O.E.M. ignition switches! Corvette and Viper switches are in-stock and ready to use. We can also modify any other switch you may be considering for your vehicle to work with “Ignitor.”
• Tach-less input allows for easy installation with any type engine. Built-in circuitry monitors state of engine to determine when it is running.
• Optional security enable input allows for interface with security devices allowing only authorized users access to your vehicle’s ignition.
• Available retained accessory option keeps accessories live for ten minutes after ignition is turned off, or until door is opened.
Ringbrothers 04-19-2011 12:09 PM
Yes, it will work with ISIS. But, polarity will have to be switched unless the node input porgramming can be changed to accept +12 volts. The easiest way to do this is with relays... In other words, ISIS needs a ground input trigger and our stuff outputs positive.
Let me know if you need more detail.
Thank you,
Staci
Autokraft 04-19-2011 03:47 PM
Will you throw in a set of floaties if I buy this Staci?? :rofl:
214Chevy 04-19-2011 07:18 PM
I want this! May be a stupid question, but will it work with manual cars. I know you have to depress the brake.:lateral:
Ringbrothers 05-19-2011 11:45 AM
Better pictures
http://i656.photobucket.com/albums/u...s/Ignitor3.gif
http://i656.photobucket.com/albums/u...s/Ignitor2.jpg
http://i656.photobucket.com/albums/u...s/Ignitor1.jpg
http://i656.photobucket.com/albums/u...s/Ignitor4.jpg
Ringbrothers 06-21-2011 10:04 AM
Just wanted to let everyone know that we accidentally used a trademarked name for our start system. We immediately pulled the name and are trying to come up with something new. Any ideas?
