Car Stereo JL,Alpine,SI
So first off everything is brand new and only was used for mock up in my 69 camaro that was never completed.I sold the car and part of the deal was i got to keep the stereo.As you can see in the pic I have boxes for most items.The amps spent a couple of years mounted in the car but were never used.Masking tape was used on the 450/4 so it will take some work to get all that off.Im looking to get somewhere around $1500+ shipping but im open to any offers.
SI Mag 12" D2 subwoofer 900 watt RMS(will handle 1000+ easy) Retail was $519 JL 1000/1 1000 Watt RMS mono block Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V) THD at RMS Power: <0.05% @ 4 ohm S/N Ratio: >95dB below rated power Frequency Response: 5Hz - 500 Hz Damping Factor: >500 at 4 ohms /50Hz Input Range switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions: 19.7"L x 9.25"W x 2.36"H JL 450/4 Amp 4 Channels 1 and 2: Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V) Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V) Channels 3 and 4: Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V) Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V) Peak Power Output 900 watts approx. Alpine IVA-D310 LCD " Fully Motorized Monitor DVD-R/RW Compatible MP3 and WMA Playback 50W MAX x 4/18W RMS x 4 High Power Amplifier Diamond Audio s500s with silk tweeters Type: Separate Drivers: Tweeter, Midbass Drivers per Channel: 2 Power Range (watts): 20-150 Imped (ohms): 4 Crossover Included: Y Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 91 Freq,. Response _Hz to _kHz (±3dB): 58-24(a) 58-22(s) Woofer Cone Material: Kevlar Sandwich Tweeter Cone Material: Aluminum / Silk Mounting Type: Flush, Surface, Angle Mount Depth Largest Driver: 1-7/8" Diameter Largest Driver: 5-1/4" Diameter Tweeter Driver: 1" Diamond Audio s600s with silk tweeters 6" 2-Way Component System Hexacone Technology: Kevlar / Nomex / Kevlar honeycomb sandwich 1" SILK Dome Tweeters Butyl Rubber Surround Proprietary Cie-cast Alloy Chassis Flat Progressive Spider Competition Grade Crossover Included Tweeter Mounting Type: Flush, Surface, Angle Impedance (ohms): 4 Top Mount Depth: 2-1/8" http://i71.photobucket.com/albums/i121/luma51/photo.jpg. |
Would you sell the JL amps separately?
Thanks! |
Yeah I might do that PM me an offer.If you dont have a sub that can handle that JL 1000 that sub is really nice.
Nice Avatar...:lol:
(glws!) |
PM sent
Amps and diamond speakers sold.
Asking $300 for alpine DVD head unit Asking. $275 for Stereo Integrity Mag 12" sub Again both items have never been used for anything except mock up.Both items are in original boxes. |
New Price
$500 takes both! |
| All times are GMT -7. The time now is 02:26 PM. |
