-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   Tachometer reading too fast (https://www.lateral-g.net/forums/showthread.php?t=32424)
NAPA 68 06-19-2011 12:15 PM
I have a SW vintage mechanical tach that I had retrofitted by Classic Insturments. The unit is about 4 1/2 years old. All of a sudden, it is now reading about 1000 RPM higher and reads higher throught the RPM sweep. Nothing has changed and the car still runs fine. Any ideas before I send the unit back to Classic Insturments?
Thanks,
Tim
marks914 09-05-2011 08:33 AM
Sounds like noise in the system. Try switching the dip switches back and forth and then back to normal mode for your setting. Usually that does the trick for a climbing tach.
kyle @ rfw 09-07-2011 12:29 PM
Try double checking the grounds on the engine and the gauge.
