-   -   18/20 wheel & tire combo (https://www.lateral-g.net/forums/showthread.php?t=3276)
bosstyrac 01-30-2006 08:46 PM
i got a 69 camaro planning on lowering it what size tire's with 18/20 combo probably a 18x7 front wheel and a 20x8.5 or 20x9 rear wheel
post info and picture's
TravisB 01-31-2006 06:10 AM
they will fit....do you plan on minitubbing???
fletcherscustoms 01-31-2006 07:40 AM
I am curious to get in on this also. My car is mini tubbed and I am looking for 20/18 options as well.
markss28 01-31-2006 08:41 AM
If your car is already minitubbed then you should try to fit a 20x12 in the back.
Check www.introwheels.com and look at there muscle car gallery. There is a 69
with 18s front and 20 back that look killer.
how much tubbing does your car have? (like in inches)
TravisB 01-31-2006 09:04 AM
I believe a 20x12 would fit but not sure if the car would go as low as it would with a 20x10 because of the factory outer wheel house....I may be wrong though.
fletcherscustoms 01-31-2006 10:18 AM
I considered 20x12, but I think tire height woudl be liek 29" which would cause problems on car with 3" drop springs. I think 18x12 will be where I go with this car or maybe a 19x13 if I can find the right tire
My car has the DSE kit in it
Bowtieracing 01-31-2006 10:56 AM
Will above work?
rocketman 02-08-2006 11:52 PM
the new zo6 has a 325/35/19 might give it a look or 335/30/18.
