SBC 406 with LT1/T56 Transmission
This engine & transmission is great for 67 to 69 Camaro or 68 to 72 Nova.. The transmission was in a 68 Camaro..
406 SBC- original Chevy block 9.1 compression ratio Lunati Rotating assembly -internal balance Professional Products Harmonic balancer Splayed main bearing caps AFR cylinder heads- 195 Crower Cam- Lift int 540 exh 565 Duration @.050 int 236 exh 244 LSA 114 deg Hyd/Roller Cower Hyd/Roller Lifers & rockers MSD Distributor Aluminum water pump Power Master High torque starter Edelbrock Air gap intake with 750 HP Carburetor or DFI complete system Racing engine Analysis - 526 HP & 526 TQ LT1 /T56 Transmission Rebuilt by Rockland Gear- 20k miles on rebuild Mcleod billet flywheel with clutch & pressure plate ATS transmission support Driveshaft Asking 8500.00 for everything.. have an option on intake systems.. only one set up goes with engine Have a new set of Dynatech headers for Camaro/Nova.. additional 400.00 http://i1015.photobucket.com/albums/...n/IMG_1469.jpg http://i1015.photobucket.com/albums/...n/IMG_1470.jpg http://i1015.photobucket.com/albums/...n/IMG_1471.jpg http://i1015.photobucket.com/albums/...n/IMG_1472.jpg http://i1015.photobucket.com/albums/...n/IMG_1473.jpg http://i1015.photobucket.com/albums/...n/IMG_1474.jpg http://i1015.photobucket.com/albums/...n/IMG_1475.jpg |
Are you willing to separate? IF so, how much for the engine and headers? Bill
I will let go the engine with headers for 6800.00
Cris, how much for the trans setup??
Rick- I only really included the trans set up to sweeten up the deal for somebody looking for a complete drivetrain.. If I just sell the motor by itself.. I am good with that.. Trans can be converted for an LS set up pretty easy.. & can use it on one of the shop builds
It's good Cris thats is what I wanted to do. Oh well I will keep looking. |
Dfi
I need to sell the motor first before I know which intake system I will be left over..
Bump!
I still have all these parts available.. PM me with reaonsable offers.. I will separate components.. Soon I will have a list of parts I have sitting on shelf that are just taking up space.. |
Tried to pm regarding engine parts. Your in box is full.
| All times are GMT -7. The time now is 08:23 AM. |
