1000 HP 69 Camaro rear end help!
hey guys, I trying to configure a rear end for a high performance street Camaro. I know I'm going to be using a 9" rear end, but I don't know what kind. I've been looking at fabricated housing from companies such as Moser and Currie, but I get different opinions on things such as semi floating and full floating, and detroit locker to a truetrac. I want a very strong rear end, but of course I want to be realistic at the same time. So as far as a complete rear end, what are my best options?
Thanks, Pasquale |
If you are going with a 9 inch, I have a brand new high horsepower third member for sale.
https://lateral-g.net/forums/showthread.php4?t=33682 |
http://thegmr.com/ This might work for you
Thanks that diagram does help. But does anyone know what the strongest 9" would be that would also be driver friendly on the street?
strange nodular case, wavetrac diff, 35 spline axles, and chris alston fab 9 housing with bracing.
i have a fab 9 housing, strange case, and 31 spline axles with detroit locker. its held 800+ hp for a couple years with no problems. |
What are you going to use the car for? How are you going to make power? What sort of tires are you going to run?
I'm targeting 1000hp at the rear wheels. I'm running a Currie F9 IRS setup, with custom CVs from Driveshaft shop, Wavetrac, 35 spline, etc. That said, I'm building power with turbo's, which is "gentler" on the drive train. I don't plan on dead hooking at high RPM, producing large amounts of driveline shock. Besides, I expect the rear tires (345/30R20 Michelin) are going to spin if I hit it too hard in 1st, 2nd, or 3rd (and perhaps all the way into 6th). The hardest part I've found is finding the transmission (without going to a Lenco) that will handle the torque. RPM Transmission helped me with a T56 Magnum and all the mods. Have you thought about what ring and pinion your going to run? I'm using a 3:50:1 (pretty steep) and, without a dedicated track toy (i.e. I do plan on using it on the street), the options I found were limited. Thoughts? :cheers: |
If your running 345 street tires a truetrac and 31 spline axles are all you will need, the tires will dictate EVERYTHING, and the additional 500hp you have will be good on the dyno.
my .02:thumbsup: |
Gmr Full Floater
With 1000 hp with 295/35 18s you dont need to worry about rear end strenght at all. Tires will spin like an ice when hit the go pedal. |
