Vortech S-Trim setup for 302, 351W SBF Ford
This setup's complete, running right now, pullied for approximately 11psi with 351W/Edelbrock Victor Jr. heads/TFS hyd. roller. Head unit's in nice shape and carb' hat and ProCharger "Big Red" valve are both like-new. Parts are in Northern California, zip 95991 (Yuba City)
Pic's here: http://www.norcal1320.com/forums/sho...p?t=1191201514 Quick Fuel 750 Blow through Carb, 11.8:1 A/F ratio at W.O.T. (perfect!) Vortech V1 S Trim With 10 Rib Pulley kit and/or 8 Rib Pulley Kit for space constraints in whatever you're puttin' it in ProCharger "Big Red" Blow Off Valve, open style, the best on the market Extreme Velocity Carb Hat All the nuts and bolts. Kit will fit either 351 or 5.0/302. Currently setup for 351. With the 10 Rib setup I have seen 11lbs on my low compression setup. And dipped into the 10's with a 351. $2000 Plus Shipping (probably no more than $50-60 to the lower 48 states) Greg (530) 339-2093 |
| All times are GMT -7. The time now is 11:49 PM. |
