big block chev.EFI.holley comander 950
I have become a ls addict so I no longer need this set up is new in the box and is complete with intake [oval port] word has it it can be ported for rectangle port heads also.this is a self learning efi multi point not a 4 barrel replacement. intake,throttle body,fuel rails,wire harness,ecu,o2 sensor this can be adapted to fit other aplications as well. I might sep the intake if you are looking to use it for something else.
looking to get 1,750 out of it. http://i643.photobucket.com/albums/u...rip2011037.jpg http://i643.photobucket.com/albums/u...rip2011039.jpg |
also looking for old gas pumps,2002 or newer 4l80e tranny or maybe a lathe for trades.;)
Would this be compatible with a supercharger
yes you can use this in a supercharged application.just need to size the right injectors and fuel pump.
Which kit part # is this? Thanks.
| All times are GMT -7. The time now is 03:49 PM. |
