1970-1981 Camaro/Firebird Coil-Over Conversion System 2nd Generation F-Body Single Ad
1970-1981 Camaro/Firebird Coil-Over Conversion System 2nd Generation F-Body Single Adjustable Front Pro Coil System Suspension Height Adjustment0.0-2.0 in. lowered frontCoil-Over Kit PositionFrontRecommended Front-End Weight1,701-1,900 lbs.Shocks IncludedYesAdjustable ValvingYesInternal DesignTwin-tubeGas ChargedNoNumber of Valving Selections18Extended Length (in)15. in.Collapsed Length (in)10.5 in.Threaded Adjustment Range3.000 in.Upper MountStudLower MountBar pinShock Body MaterialAluminumShock Body FinishClear anodizedBushing MaterialPolyurethaneBushing ColorBlackCoil-Over Springs IncludedYesSpring Rate (lbs/in)550 lbs./in.Spring FinishSilver powdercoatedCrossmember IncludedNoAdjustable Mounting Bracket IncludedNoHardware IncludedYesWelding RequiredNoQuantitySold as a kit.NotesSingle adjustable coil-overs, designed to fit applications with small block engines. Shocks are remote ready, they can be used with the QA1 two or four channel remote adjustable system. These QA1 Pro coil-over systems are engineered from the ground up to offer unmatched performance over stock suspension setups. Pro coil-over systems utilize adjustable and non-adjustable coil-over shocks and springs, designed specifically for replacing the factory shocks and springs. This combination offers ride height adjustment and variable position valving adjustment (where applicable) for performance not found in other kits. Choose these QA1 Pro coil-over systems for your next suspension upgrade. QA1 offers its Pro Coil System with single adjustable shocks for the daily driver. Compression and rebound adjustment is made easy with one easy-to-reach knob for simultaneous adjustment. With 18 valving options, you’re able to fine tune your suspension for the ride you’re looking for.
Starting at $459.95 |
Don't settle for a new tie, blue jeans or underware for Christmas this year. Get what you really want ! That right let me introduce you to http://www.camaro5.com/forums/attach...2&d=1307282293 |
