67-70 Mustang Ride Tech Parts
4 Attachment(s)
Have a set of Ridetech Master Series front and rear shockwaves upgraded with Internal Ride Height Sensors. These have only been used to mock up the car's ride height.
Rear Shockwave 7000 Master Series Pair with external Sleeves to protect from heat Part number# 2115071 single adjustable upgraded to Internal Ride Height Sensors Compressed: 11.5" Extended: 16.5" Ride Height: 14.5" Stroke: 5 Mount: Bearing Retail is $900 plus I paid 400 per bag to have the internal sensors put in Looking for $1200 Front Shockwave 1000 Master Series Pair Part number # 21240101 double adjustable upgraded to Internal Ride Height Sensors Compressed: 10.6" Extended: 14.75" Ride Height: 13" Stroke: 4.1 Mount: Bearing Retail is $1200 plus I paid 400 per bag to have the internal sensors put in Looking for $1450 Ride Tech 5 Gallon Air Pod with twin compressors, upgraded ECU to ridepro and optional Internal Sensors and remote key fob option - brand new - used only to mock up air suspension With the options and add on's this sells for $2750 Looking to get $1900 The Ride Tech parts were only used for mockup, and have no actual miles on them. I decided to change engines in my car, and go a completely different route with suspension; as a result, I have no use for the ride tech stuff. Also have 67-70 Mustang Baer Brake Hub assemblies with Baer Brake bracketry for 13 or 14" brakes, and Baer Brake rotor hats These aren't normally sold in pieces like this (the 13 or 14" 6 piston baer kit will run about $2400) All you would need are rotors and calipers Looking to get $500 for the brackets, spindles, and hubs Also have a 67-70 Mustang Rack and Pinion Complete steering setup - this was used for approx 800 miles (a summer and a half before I took my car off the road to change it) The new front clip I have includes a rack and so I have no use for this anymore This comes with the power steering pump, and bracketry for a windsor based small block Looking to get $800 Thanks Tom |
pm sent
pm replied
pm sent on airpod
Air Pod is still for sale.
Front Upper/Lower Control Arms, Muscle Bar and Rear 4 Link have sold**** |
1 Attachment(s)
Pic of the shockwaves
| All times are GMT -7. The time now is 03:21 PM. |
