-   -   TKO500 Mcleod Twin disc Lakewood bell and lots more! (https://www.lateral-g.net/forums/showthread.php?t=34667)
74ls1nova 12-08-2011 10:04 PM
Tremec TKO 500 for chevy. It is actually an older version of the 500 Believe it was called a TKO2 originally rated at 475 ft lbs
26 spline input shaft
3.27 first, 1.98 second, 1.34 third, 1.0 fourth, .68 fifth
Pro 5.0 shifter with hurst knob with button.
Like new has less than 200 street miles on it no track use.
1000.00
Mcleod RST twin disc. Part number 6913-07 New only bolted up. The mounting plate has one stripped hole and will need to be replaced. For the asking price i will have one drop shipped to the buyer.
Application: GM 1955-1985 V8 ; Use w/ Small Diameter 153T Flywheel. 1-1/8 x 26 Input
Rated to 800hp
350.00
Mcleod Adjustable Master Cylinder. Part number 139001 Used for less than 200 miles. F body 13/16 bore steel with -4 an outlet.
150.00
Lakewood bell housing 15020 for SBC and possibly work with LSx engines with special pilot bearing? Not 100% on that. for external slave cylinder.
200.00
Billet 30lb internal balance flywheel for one piece rear seal SBC. New only bolted on. 100.00
New sachs stock replacement internal balance flywheel for 2 piece seal SBC new only bolted on. 90.00
I also have the throwout bearing and clutch fork for the setup that i can include.
The best way to reach me is email call or text. I will get pics upon request but most of this is self explanatory.
[email protected]
417--294--7869 Thanks David Please no calls after 8pm central
74ls1nova 12-10-2011 06:04 PM
Bump. Prices are OBO
74ls1nova 12-20-2011 08:29 PM
Lowered prices! Lets make some deals
speedshopmike 12-21-2011 12:07 AM
please PM me with your absolute bottom line price on the tranny.
thx,
-m
74ls1nova 12-23-2011 09:54 PM
http://i1100.photobucket.com/albums/...s/IMAG0363.jpg
http://i1100.photobucket.com/albums/...s/IMAG0366.jpg
http://i1100.photobucket.com/albums/...s/IMAG0367.jpg
http://i1100.photobucket.com/albums/...s/IMAG0365.jpg
eddiep 12-25-2011 08:33 PM
Sent email on the clutch.
