-   Cars Sold (https://www.lateral-g.net/forums/forumdisplay.php?f=77)
-   -   68 Camaro tube chassis (https://www.lateral-g.net/forums/showthread.php?t=34719)
DragRacer404 12-13-2011 06:16 PM
Full chassis car that just passed NHRA certification for 8.50's. Was just a few small bars short of making 7.50 cert, so would be easy to make it there if need be.
Funny car cage with 2x3 boxed frame rails. 1 piece fiberglass front end and stock style fiberglass hood. Side Lexan and frames (needs front and rear lexan), the back half of the car's sheet metal is completed just need to get firewall & trans tunnel aluminum.
Rear : 12 bolt with 4.30gears, spool, and Mark Williams axles. Its a ladder bar car(cant think of brand off hand), rear shocks ar Koni coilovers, Willwood brakes. 15x15 Weld Draglites.
Front : Strange struts, strange rack, Willwood brakes, 15x3.5 Racestars.
Misc. : Custom Aluminum radiator with fan and overflow tank, Small enginebay mounted aluminum fuel tank, Willwood Brake pedal/master cyl. assembly, Grant wheel, Mid plate,@ BBC and SBC motor plate.
Car curently has tabs and trans crossmember setup for BBC/Glide. Person that owned car before me painted the car some kind of military looking green but has since been sanded and primed. And im sure there is more stuff that im leaving out but getting late and cant remember everything right now. More pics can be seen here : http://s174.photobucket.com/albums/w91/95z28racer/
$5500. Open to trades
