Ls3 with tvs2300 magnachager in 1971 skylark
Hi guys, I have an ls3 with a tvs2300 magnachager that came out of a 2010 camaro that I want to swap into my 1971 skylark. It didn't come with any accessories as the guy keep them for the motor he put back into camaro. Does anyone know if I will run into issues installing the engine with this blower into the car and also what accessories should I use, corvette, aftermarket?
Don't make this harder than it needs to be, talk with the seller and see exactly what accessory drive setup he had and go buy that.
when you look into it, look into an 8 rib or bigger system as you don't want belt slip and they are known for it. You planning on running a/c?
Wegner has a front drive setup if you want to go aftermarket.
What kind of power you looking to make? That kit may be over kill. |
Camaro5 is always selling used blowers and it would be nice to know what will work. I have been tempted by some good prices over there, but not sure how much it will cost to get a drive system to work.
I've got a vortech T trim on my LS3 running about 7 psi on the 6 rib setup with zero belt slip issues. If you plan on running around 10 psi you should be okay with a regular 6 rib setup. You shouldn't have any issues running regular corvettes drives.
I have the TVS2300 on my 2010 camaro and running 9lbs and have NO issues with belt slip with the factory setup.
You need the accessory drive and water pump from the 2010 camaro. Vette stuff wont work with the Camaro supercharger as the spacing is different. have to decide if you want aftermarket or the "truck style" accessories the camaro comes with. |
| All times are GMT -7. The time now is 07:49 AM. |
