clutch adjustment help
Ive just completed and test run my t56 in my 69.. im using a wilwood slave , a ram t/o bearing, mcleod streetpro clutch ..150 clearance ,, geez , im amazed at how much the feel of the car has changed from the old t350. super responsive with the lightened flywheel.. the clutch works realy well but engages rite off the floor.. what adjustment do i make to get it up a little but still work as is.? if i wind the rod out wouldnt it pre load the slave cylinder ? is that ok? Gav :) |
Do you know if a setup like yours on the hydraulic clutch would work using a TKO 600? If so what bracket etc.. did you use?
Thanks |
| All times are GMT -7. The time now is 03:51 AM. |
