-   -   TKO-600 with LS install kit-new (https://www.lateral-g.net/forums/showthread.php?t=35294)
ndm68 01-28-2012 11:55 AM
SOLD SOLD SOLD
Brand new never installed into project car Kiesler 5 speed complete conversion kit with LS2 engine
TKO-600 650hp/650ft-lb 5 speed, low profile internal offset shifter, keisler mini billet shift tower and lever stub, 4616 chromoly gear set, 1pc counter shaft, dual speedo outputs, reversed and neutral switch output,
ratios 2.87,1.89,1.28,1.0,0.64
GM performance synchromesh trans fluid
Complete flywheel/clutch combo for LS engine, pressure plate, disc, pp bolts and, Hurst classic 5 speed knob
Hydraulic kit, master cylinder, slave, throw out bearing, resevoir assembly, fluid lines and fittings
All new and never installed
http://i766.photobucket.com/albums/x...parts003-1.jpg
http://i766.photobucket.com/albums/x...parts002-1.jpg
http://i766.photobucket.com/albums/x...parts001-1.jpg
http://i766.photobucket.com/albums/x...parts004-1.jpg
NOPANTS68 01-28-2012 02:05 PM
left you a VM.
ndm68 01-28-2012 05:11 PM
SOLD SOLD SOLD- to local Forumn member:)
