New Product: 64-66 Mustang RideTech TruTurn
Here is some information on Ridetech's newest TruTurn application:
New Product: 64-66 Mustang TruTurn Since its introduction last summer, the Tru Turn has been a blessing for Camaro owners looking to fix the obvious flaws of their OEM steering system. Ridetech Camaro customers have been able to improve their camber gain, eliminate bump steer, and fit larger wheels under their fenders with the help of the TruTurn system. Now this spring, Ridetech is proud to announce that 64-66 Mustang owners will now have the same opportunity now that Ridetech offers a new TruTurn package engineered specifically for Mustang frontends. http://www.ridetech.com/images/forum/tru-turn.png What is it? The TruTurn system is an upgraded steering system that includes the following:
What does it do? The early Mustang frontends have very poor suspension geometry...the tires lean outward around turns, the bumpsteer is bad, and there is little room to run a wide wheel. The TruTurn system resolves ALL these issues... the tires now lean INTO the turn, the bumpsteer is 0.000" through 5" of suspension travel, and you now have clearance to run up to a 245mm Tire. General Features
Frequently Asked Questions: Q. Do I have to modify my oem subframe? A. No modifications are necessary at all. Q. Can I use my existing OEM or other aftermarket dropped spindles with this system? A. No…the RideTech spindle is a critical part of the whole system. Using a different spindle will create highly unfavorable suspension geometry and would be incompatible with our steering arms. Q. What is “bumpsteer” and why should I be concerned about it? A. Bumpsteer is a term that refers to the control arms and the steering linkage moving in different arcs as the suspension moves through its travel. When this happens the tierods will move the steering arms [and therefore the wheels] in directions that the driver does not intend. This leads to an “uneasy” feeling car. Some OEM cars [especially older musclecars] can have a lot of bumpsteer…as much as 1″! Imagine the toe setting on your car changing unpredictably as you go down the road! The Tru Turn system nearly eliminates this situation…the bumpsteer is 0″ over the entire 5″ of suspension travel. This leads to a very stable and comfortable feeling vehicle. Q. What is camber gain and why should I be concerned about it? A. Camber gain refers to the rate of camber change the spindle will see through the range of suspension travel. With most OEM cars [especially older musclecars], the OEM suspension geometry will lean the compressed wheel OUT when turning. [Take a look at an early Mustang taking a hard turn] With the Tru Turn suspension the compressed wheel will lean INTO the turn, keeping the tire squarely on the ground thereby offering more lateral grip AND offering a more stable turning experience. Award Winning Tru Turn Announced at the 2012 Hot Rod and Restoration Trade Show, Ridetech won one of the coveted Innovation Awards for the new 1964-66 Mustang TruTurn Package. http://www.ridetech.com/images/forum/trophy.jpg http://www.ridetech.com/images/forum...g-tru-turn.jpg More information at: http://www.ridetech.com/info/2012/03...tang-tru-turn/ Where to buy: Online, Phone: 812.481.4787, or an authorized RideTech dealer. |
Nice looking setup. :thumbsup:
| All times are GMT -7. The time now is 01:59 PM. |
