-   -   LS6 intake setup, Corvette LS1 cam, LS2 cam sensor, rockers, Vortec parts (https://www.lateral-g.net/forums/showthread.php?t=37392)
jwcarguy 06-30-2012 08:16 AM
-I just got a excellent complete LS6 low mileage "takeoff" setup (with under 300 miles!!)
complete setup includes:
LS6 intake w/ seals (#12561184), fuel rails, fuel injectors (28lb., #12561462) w/ retaining clips, cable throttle body with the tps & iac sensors, pcv hose assembly & manifold retaining clips, purge solenoid & hoses, & mounting bracket, intake mounting bolt set, map sensor, throttle cable bracket & mounting bolts, etc,
This is a rare find, to have a basically "like new" setup, that is this "complete"
$575 shipped (lower 48) (price is firm on this one)
- uesd GM 200 Corvette LS1 cam #12560968 (#0968 on cam)
specs: 198/209 dur. 500/500 lift 115 LSA $60
- complete set ( for two heads) of low mileage (40k) rockers and stands from a 6.0L (will work on 4.8L, 5.3, 6.0 LS1, LS6)
$60 for both
- LS2 cam position sensor low mileage (9k) $30
- complete 2002 LQ4, LQ9 6.0L / 5.3L truck intake setup, with (65k miles) complete with fuel rails, fuel injectors
asking $75 obo
will ship at buyers expense
most parts will fit various LS1, LS2, LS3 , LS6 , 5.3, 6.0 L92 engines used in street , pro-touring , offroad sand rail and drifter , drift cars
In Las Vegas
PM, call/ text (702) 677-4085
[email protected]
Ummgawa 06-30-2012 10:00 AM
Jeff is a stand up guy and I recommend him. Thanks Jeff.
jwcarguy 07-04-2012 06:49 AM
Holiday bump!!
