-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   Oil pan ls3 416 (https://www.lateral-g.net/forums/showthread.php?t=37413)
snappytravis 07-02-2012 02:08 PM
Oil pan ls3 416
I need a little help, what is a good oil pan to go with for my ls3 that I am putting in 69 camaro, I see holley has one for around 400.00. I would not mind taking the car to the track someday and doing a little road racing, possibly, I also see the canton around 500.00, I will probably be driving on the street mainly, or do I go with the gm conversion pan that they offer throught performace parts for around 250.00. Not sure if I really need a 500.00 oil pan, thanks
Chad-1stGen 07-02-2012 02:54 PM
The GM conversion pan is pretty deep. Some guys don't care for it as it does hang down below a 1st gen Camaro cross member.
If you want to stick with a cast aluminum pan Mast makes a conversion ban with nice baffling.
I went with an Autocraft pan (Made by Champ) as it has actual trap doors as I plan to track the car.
Autokraft 07-02-2012 08:12 PM
Snappy give me a call, I can help you out on a nice setup.
Kurt
Autokraft.org
715-874-5921
snappytravis 07-02-2012 10:10 PM
will call you buddy!
214Chevy 07-03-2012 09:50 AM
Originally Posted by snappytravis (Post 422474)
..... I will probably be driving on the street mainly.
Originally Posted by Chad-1stGen (Post 422478)
....If you want to stick with a cast aluminum pan Mast makes a conversion ban with nice baffling.
That Mast pan is a pretty nice pan. I may get it. Nothing wrong with a cast pan since you are just like me..."mainly a street car." Mine is 100% a street car. It'll never see a track so cast is fine for me.
